查看: 5940|回复: 15
[分享] 初学GRX,做了几个GRX,有源码
发表于 2008-8-18 21:44 | 显示全部楼层 |阅读模式
entity/obj(1000),pla(6),box,sol,sol1,ent,ent1( B7 ?9 u* t" e" s& p/ M* \
number/nm,distan(7),mindis(6),p(6)
7 G% H9 o8 f7 Z% b: Lnumber/xmin,xmax,ymin,ymax,zmin,zmax,mat1(12)% M  \" ~1 m- U( U9 O/ Q) h
number/MAT2(12)( J$ @# f: o5 L! g2 J. _! h- A( m
data/ofset,0.37 t8 h% d9 t7 G) Z0 j( r: G( O
string/date1(132),date2(132),date3(132),date4(132)( w/ F+ o- T: a) M  p8 d
7 S4 P+ |* v: ]         $$程序加密,用时间限制使用权限$$/ P" X* I5 R: C$ g& |; v4 L  t$ ~
N01:
/ i: D8 K! J" u2 K+ c/ b0 ?date1=substr(date,1,2)
- k6 W4 d' J+ I7 z; Ydate2=substr(date,5,2)
8 N+ F9 F& h1 ^1 p% J$ gdate3=substr(date,9,2)
( A+ D- \7 ~4 s0 [1 j. \6 c/ Cdate4=date3+date1+date2# o: O0 \0 P9 A* Y0 b: l" ]% g
$$PRINT/DATE,DATE1,DATE2,DATE3,DATE4* ]0 `. ]2 g, D8 q+ r
$$messg/date4: h% ^+ P( w4 w) N9 M1 O
if/valf(date4)>071001,jump/messg1:7 x" `$ E$ T+ m
8 j6 u! l* G! k% O8 o: S' e) e" s1 m9 _: Q/ g3 J7 E
start:
2 S; ?. P4 ^1 T/ }mask/71
) r1 `8 I' C& _$ [- K  ident/'select object',obj,cnt,nm,rsp
/ X) k2 R" P5 s2 Y/ ]' K- o- F5 b  jump/start:,hal:,,,rsp4 W* m6 v  o) H- d- c
                 ifthen/nm>1000
" Z' k" s0 A& U8 |  messg/'选择的对象超过1000个...','请重新选择': y" H7 A. S# V: ?6 E% v, J6 y
  jump/start:7 d, U& j+ @7 U
                else
. A6 a- q2 j0 D3 z: H# N2 ?  jump/l00:
- k& y  q. @, T3 G9 vendif
6 g5 j5 d* E- A; z9 D/ ~1 I6 W, ~, t8 Zl00:& o  O* S* y! L8 B: {; H
param/'输入偏置距离','Offset = ',ofset,altact,'======info======',rsp
& _, r, q$ x# i& A9 [jump/l00:,hal:,,messg:,,,rsp. j/ U: @! `+ b3 t
$$            print/istr(nm)7 s5 T4 @3 a/ l4 W
do/l10:,i,1,nm  " D* w8 ^0 H4 l- L
p=solbox/obj(i) $$获得对象的坐标极点  D% q. ?  g# s7 ^$ H0 v( o7 i
% @8 [; O0 u# ]# k) j2 @      ifthen/i==1
+ n+ R8 g2 Q* W( R7 |  xmin=minf(p(1),p(4))& O' M# _# X4 L% L) u6 X2 b! E6 ?
  xmax=maxf(p(1),p(4))
0 ^! V' q% V! a7 k$ u  ymin=minf(p(2),p(5))1 H2 L7 ?4 h4 ~& @, Q
  ymax=maxf(p(2),p(5))/ s5 M5 S- k1 r) ^- `
  zmin=minf(p(3),p(6))
& H% n; ^% |2 ^+ d5 d" M' ?0 Q  zmax=maxf(p(3),p(6))
- T& A, O$ L% y! B( g0 Felse
5 e8 v* S4 Y- D+ l" ^6 r  xmin=minf(xmin,p(1),p(4))
9 }4 j6 J0 {9 x  xmax=maxf(xmax,p(1),p(4))
' w$ C# B% @# @  C# L8 g& W( b  ymin=minf(ymin,p(2),p(5))" f0 r. F; a. W1 B% _
  ymax=maxf(ymax,p(2),p(5))
0 x9 J1 a* ?! `- ~9 z  zmin=minf(zmin,p(3),p(6))2 y9 S& n0 V4 m8 C( _
  zmax=maxf(zmax,p(3),p(6))) i; F9 G' ~& _( U
endif# Y2 s/ Y- B* ?  y3 z) _5 v
                $$print/xmin,xmax,ymin,ymax,zmin,zmax
: |9 s: O7 }* ^0 |x=absf(xmax-xmin)
$ w  p7 v: {0 y6 D2 hy=absf(ymax-ymin)" m+ q; Z4 o3 R$ O
z=absf(zmax-zmin)1 J7 ]* i  E6 k$ l8 ]
" I$ a+ Y  c8 d0 _& Z2 X0 }; iif/x==0,x=1
2 O% p1 `, [& G4 H: Cif/y==0,y=1 2 |3 Z1 s# s, K/ B9 h
if/z==0,z=1
1 ]! k% s+ w4 e& ml10:
' f+ y+ B3 B$ c+ o" N, vdraw/off
5 y% Q' X! p1 {# ?/ S$ a9 d+ C8 ?pla(1)=PLANE/YZPLAN,(xmin-10)4 e. u/ C0 D! B. D0 F+ e
pla(2)=PLANE/YZPLAN,(xmax+10)6 v  H' h9 G4 I8 `7 o
pla(3)=PLANE/XZPLAN,(ymin-10)
! {. q7 R3 ?2 _! C  Npla(4)=PLANE/XZPLAN,(ymax+10)! m' r/ Z) s7 U
pla(5)=PLANE/XYPLAN,(zmin-10)
7 J1 o0 b7 b" V' x4 k% J& xpla(6)=PLANE/XYPLAN,(zmax+10)
. {+ T/ O& w/ Y- w- kl20: " s- C+ |# g3 Y2 n- C" x5 L
  do/b1:,i,1,nm  J. ~  [. ?) M+ r, ^1 \
  distan=reldst/pla(1),obj(i) $$测量两个物体的距离. Z# s+ U' `0 q( ]
  ifthen/i==1
: _0 B8 T0 s' F8 T% J  mindis(1)=absf(distan(7)) $$mindis(7)为距离
! g, l9 ]4 ~+ F7 L  jump/b1:" ?+ ]( n6 n; x' F
  endif
, r* t4 {$ f& U9 P  mindis(1)=minf(mindis(1),absf(distan(7)))3 ~  L4 M* ~9 o6 M3 _# m9 [1 T' _
b1:
0 m: N+ o* e4 H$ ?* w  T  l/ _                 $$print/mindis(1)$ A! u3 f/ h' c* Q3 J  Q& t3 m
l30:
% G8 |6 g( M1 _+ v3 ^1 V: ]  ~  do/b2:,i,1,nm$ H! L* A- y  Y( o) ?9 Y; e( O
  distan=reldst/pla(2),obj(i)+ ]$ \$ ^3 k% ]. F
  ifthen/i==12 f9 l9 n+ ~* A1 u& L
  mindis(2)=absf(distan(7)) 0 |# i0 y: x: K, x/ f1 \2 f& N
  jump/b2:8 ?  i2 \  }" T% V
  endif
, ~1 t1 B5 d' P/ j2 `  mindis(2)=minf(mindis(2),absf(distan(7)))
3 ]' s. q* Z0 a+ n7 sb2:3 I; R; [! a$ N9 c. s' [6 O4 r
  $$print/mindis(2)
# T. Y; w$ J. E4 D5 @/ C- e
8 X, }5 g3 S& n! m( R2 S$ M1 f! Xl40:. {1 M) ^7 |# C
  do/b3:,i,1,nm; l/ h+ d4 P. Z) G9 J$ D
  distan=reldst/pla(3),obj(i)' F, J! B* V" `# G: n; S
  ifthen/i==1" l4 ~) ^. P4 t! A
  mindis(3)=absf(distan(7))
: h- A" e: v9 b3 j1 Y: l* {4 [  jump/b3:
7 @& G% L9 ?0 Z4 W. O. q8 Y4 G6 P  endif- P0 b. f" H8 T# ~
  mindis(3)=minf(mindis(3),absf(distan(7)))
$ Y& w7 W# ^6 U( [b3:
, T/ ]! I- ]8 b3 f) u  $$print/mindis(3)
: h" h' A- t6 M
: a6 G5 U8 B! u  E. @- W0 o9 rl50:
' x3 m5 B8 r7 i9 o  do/b4:,i,1,nm
& c- Q/ p5 f' g  distan=reldst/pla(4),obj(i)
$ K/ ~4 b' b! V+ B' ]  ifthen/i==16 u: }2 @$ s! t4 e% W2 o
  mindis(4)=absf(distan(7)) " }# n+ \& g( K4 j! {) u
  jump/b4:3 a) b& G8 S( l3 D# j6 b" h# _
  endif
  v5 n  V" h" i! l. P& O2 |( C  mindis(4)=minf(mindis(4),absf(distan(7)))9 p  ]1 _0 N  W$ e! R) b$ B5 e: `7 X
b4:0 h' b* ^# r) ~" Y, T
  $$print/mindis(4)7 p1 t6 Z3 c3 e4 R# H; a4 o
3 l) u- `7 d4 P$ c- n6 G5 B0 @/ H
l60:
5 }1 u2 Z$ b. F  do/b5:,i,1,nm" v$ g/ b8 E# L" a1 I2 l* Z
  distan=reldst/pla(5),obj(i)
& |, Y/ Y8 N0 O2 \6 ]4 }  ifthen/i==12 V. [  w! Q! V! f' U5 b- f9 G
  mindis(5)=absf(distan(7)) + c. i' s5 u. [
  jump/b5:
3 k. O: S  C7 u  endif
9 Y; @0 X, X* S# T/ K" F( _  mindis(5)=minf(mindis(5),absf(distan(7)))
! ]; H8 e* Y- \b5:
6 a+ b4 e+ Y, H- j7 M  x& I  @4 o  h  $$print/mindis(5)5 E+ I: |, c( c0 V3 T+ a( m. _+ ~
l70:
0 ?2 s' P/ z" @6 ]7 O7 ]  do/b6:,i,1,nm
& e& m+ f$ s, i  distan=reldst/pla(6),obj(i)
) n+ \: e* M8 |, K/ V" T6 b  ifthen/i==1
8 m  l5 _4 _. U$ H! L. U  mindis(6)=absf(distan(7)) ! i& C8 }" J- h& z
  jump/b6:
8 {& L, H1 D9 q1 s2 C( A/ X  endif/ e" D# s  O# m, y- g
  mindis(6)=minf(mindis(6),absf(distan(7)))# b; ^0 k+ L) k2 c$ {
b6:
% w* C; D. Z6 z) u6 r  $$print/mindis(6)
* }2 @0 P. u- c  delete/pla(1..6)+ [1 O# u( z7 y- _1 M) ]# {) U
draw/on1 o$ \4 _; Q$ Z5 v4 p
  xmin=(xmin-10)+mindis(1). j+ R* T9 o- k4 t" v
  xmax=(xmax+10)-mindis(2)
6 L$ Z6 Y% T2 b* Z( d7 m  ymin=(ymin-10)+mindis(3)% p9 [* D. x1 @, E  i
  ymax=(ymax+10)-mindis(4): A+ G( E( f6 l: ^+ Y
  zmin=(zmin-10)+mindis(5)$ l4 W! W& Q# w6 B
  zmax=(zmax+10)-mindis(6)
: j! H' q/ k# t$$print/xmin,xmax,ymin,ymax,zmin,zmax0 P. s7 k% ?/ }% u0 t* r2 {
$$print/mindis(1)  ^. x4 u5 e) n# }7 D3 s% {
$$print/mindis(2)
- Q# i) b/ R# N$ P1 {& _' B$$print/mindis(3)
8 W* x& T3 i+ B+ J$$print/mindis(4)9 `1 I& c0 M1 w) f% U
$$print/mindis(5)6 L3 Y0 K# x1 M& P9 ?3 b
$$print/mindis(6)
* e7 _5 w0 a/ P& m+ Ox=absf(xmax-xmin)
9 i& ]; b9 n/ l* t( Ty=absf(ymax-ymin)
6 D( N! @8 K; Y6 h! y( \7 ^* Gz=absf(zmax-zmin)- V* f; ]$ ?% M$ X! g! v
) N5 F0 M" y$ v2 z, I/ k5 w
box=solblk/origin,xmin-ofset/2,ymin-ofset/2,zmin-ofset/2,$  K) V; |. r2 R  x( I# W2 x
size,x+ofset,y+ofset,z+ofset,iferr,err1:
  G; [' q* F$ \&COLOR(box)=47& W# L7 ?9 H! U) l# a* [& d& v
jump/l80:
" R3 \( C8 M1 {: W+ g* ?* Qmessg:
$ A' }0 P2 p. Dmessg/'程序使用中有任何问题',$  O0 k$ G2 }' a/ W& v
       '请联系cluwu@163.com'
! e- N' v/ y! b. p4 M* O' @* A* V7 o( m- N
jump/l00:" O8 ^4 {; A# k" t
err0:3 |; C7 D/ m( r! H1 U, b
' Z+ E4 ~5 `' S  B) a8 s$ H& I               jump/start:& m& v& H2 B9 q  i1 g
err1:  l) R' c$ E/ O
messg/'请输入正确的block尺寸',$( F: A9 p6 [. N$ f  F: f) ]
        '选择OK继续....'
/ z# @% b$ W' w9 H- U! M* ^0 sjump/start:
2 p! Y- r) l# I  b: O! }l80:
3 z1 w0 f5 \4 L/ i& H+ Y/ J       choose/'按键盘Esc键即可取消!' ,'继续创建块','布尔减',RSP8 B4 w, w# x- {( [
       jump/start:,hal:,,,start:,l90:,hal:,RSP( c5 M! x$ a5 @4 N& T+ w. O
l90:
) ~5 n. X% }* F% z* d  y/ N( _' bmask/70
8 M* B- N, G# v3 S  Vmat1=matrix/transl,0,0,0
5 |' K1 \& \+ g1 Q! ?) `ident/'select object',sol,cnt,nm,rsp
5 |) \' L. S; n9 A9 A$ l* k& Xjump/l100:,hal:,,rsp
% B2 v; m: u5 [ent=TRANSF/MAT1,sol,TRACRV. y& U  M7 r4 I1 P( A6 k
l100:
3 Z) Y1 H) z4 r! @" X" {2 Asol1=subtra/box,with,ent
0 o8 O  P- R2 T' Amat2=matrix/transl,0,0,0* O# y' K+ L  N) z$ f* @* R7 M9 S  t
ent1=TRANSF/MAT2,sol1,TRACRV* E$ L% [+ n* ?" E7 X' E* L
DELETE/ent,sol1
5 V0 [% `' m7 ~; B3 I+ T& Jl101:
% e& I; p  P3 Z% j' ^6 i1 R0 V       choose/'按键盘Esc键即可取消!' ,'继续',RSP) g+ U; A5 {" b* i% _
       jump/start:,hal:,,,start:,hal:,RSP5 P8 e' H% v5 C' P$ N: r
; z. Z. [5 W3 n% b8 U# p* p     8 D& ?9 K9 I3 E% p8 O# S. T7 T- R
hal:- A4 R! q# |5 v
     halt
2 V, o5 `1 N# z3 P$ K5 d5 jmessg1:
! W3 Q6 l" S# q) l; c. _* q, [print/'============================================================'
' `! o" Z/ E. h$ q+ |5 L. }* zprint/'=This program create by xcb!=================================='
5 [; L! a0 p3 b, o, u+ {( `/ m     print/'=This program can be used only before year 2007-10-01!======'4 M( t  F& N' C! ~- g. e
      print/'=If anything, please connect me freely!====================='
8 N' `' U0 g+ `; [      print/'=This is my e-mail:xcb@ugapi.com========================='
6 I) v$ O  [4 bprint/'=PLS call me by telephone to 15995771891==================='
2 g- V  l$ H4 S6 d' I: S6 v" Mprint/'============================================================'# k4 j) Q3 d5 w, P1 V5 y) s7 L8 f
jump/hal:
评分
参与人数 2流量 +1 激情 +10 G币 +10 收起 理由
YEQIONG2006 + 10 + 10
xcb + 1 这个就不多给分了 哈
查看全部评分
发表于 2008-10-8 00:44 | 显示全部楼层
謝謝指導分享!
发表于 2008-11-10 20:48 | 显示全部楼层
问一下,这个GRIP是关于UG哪方面的?能贴了效果图吗?' L/ {! L; F" u! o
我是新手,不好意思
发表于 2008-11-10 20:58 | 显示全部楼层
呵 谁呀
发表于 2009-3-1 01:30 | 显示全部楼层
有这方面的资料吗!
发表于 2009-3-25 11:26 | 显示全部楼层
辛苦了
发表于 2009-4-13 11:49 | 显示全部楼层
每次回头看你的源码,都能进一步了解,虽说我不知道你为什么要用这些函数,不过肯定有道理。我之前以为取极点坐标就可以了,发现是有错误的。呵呵,那只好照抄你的了
发表于 2009-4-14 10:05 | 显示全部楼层
OK,nnnak
发表于 2009-5-12 00:01 | 显示全部楼层
谢谢分享
发表于 2009-5-12 23:21 | 显示全部楼层
辛苦了
GMT+8, 2025-6-28 12:22 , Processed in 0.082646 second(s), 30 queries .
