我用UG半年了,第一次出现这样的问题,是不是装配图里面进行了错误的设置呀?我用的是UG4.0
8 Y5 s0 v+ g8 {' w[img][/img]
/ h2 k3 q) G, P2 f5 D& L
7 Y4 y, N+ u# H2 w# EView Update Report# p3 a* w* m1 X# q
4 k( e D: p: s5 w7 J
4 N4 U3 e. B) T View name: TOP@3
' E2 D+ ~, L5 B) \ View type: Imported view8 m1 a: |( i/ N# [: ]
Error: Matrix is non orthonormal., {+ R$ \0 X }
/ Z- g5 A9 K3 @$ G3 S% O Recommended Actions
# J! T5 U2 G/ w L: o$ d -------------------
7 M+ D$ j) `6 }8 ] o Choose Ignore to restore the view to the state it was in6 X4 o. I, B1 W( _% Q' r
prior to the update. This is the DEFAULT action.
! A% z7 p4 |- e7 {3 f4 q o Choose Suppress to convert the view to manual update.
' N6 b* B6 U* Y% | o Choose Delete to delete the view and all associated objects.
0 t' e. Y, d9 k" d4 J2 h3 J
3 v( o7 Y* o, E2 J/ i3 U0 n/ _ Possible Corrective Actions- n0 G$ W6 b. M, o9 w; ]+ F
$ G+ b0 G4 V6 l7 C5 P, d: J o Set view to manual update* _* C9 l. Y9 [2 H
o Set view to reference
2 i8 P( z' V3 I( V; ?8 O' @' [ o Recreate view
8 `- Y, f6 e% ^! v; _0 p o Remove view
' ~9 i9 }5 u0 E# l1 ^ o Suppress view update
5 x8 c) u" g) I8 C9 K9 A- j o Validate and fix the model
R p5 l2 j$ d" G0 x6 P) ]# q8 A9 d o Turn hidden line off
5 R1 |: w6 N+ i% b& w. r1 p o Validate layer settings
, C' M1 U; ]) |, l) O+ W% w o Unsuppress suppressed solid bodies
, B7 U' K9 x$ U o Re-establish section segment associativity in
5 e9 k7 Y- b4 F2 l! ] Edit Section Line |
