查看: 4182|回复: 5
[技术疑难] 求教:UG中,多头螺纹如何画?非三角形螺纹——矩形螺纹怎么画?
发表于 2010-8-27 20:04 | 显示全部楼层 |阅读模式
求教:ug中,多头螺纹如何画?非三角形螺纹——矩形螺纹怎么画?
发表于 2011-7-25 10:51 | 显示全部楼层
oh , my lady gaga,why doesn't anybody can help this question?
发表于 2011-7-29 22:01 | 显示全部楼层
本帖最后由 keng21 于 2011-7-29 22:10 编辑 ; f# k) h, r; ]  Y0 [# Q
jmfzxy 发表于 2011-7-25 10:51
% ]: C' r4 T* a) q4 S7 I! coh , my lady gaga,why doesn't anybody can help this question?
" W2 B* R% f' w4 d+ e
, |1 C) K, f6 j" vIt is simple, You can build a special thread in UG, just using the HELIX and SWEPT command
' x& x: Q. h) i3 a7 m9 q1. Create a helix by HELIX command (three important parameter: number of turns, pitch and radius)1 L8 U8 z2 v$ J) L
2. Then make a sketch at the start of helix( triangle,rectangle or trapezoid), y: d3 M; j; K6 g( E& `
3. Use the SWEPT comand to create the thread, helix is the guide curve and the sketch you created in step 2 is the section. the orientation method must be ” Vector Direction“ and the ZC Axis is the Vector.5 P( x2 m! @3 b: S
' w; t+ x7 m% U) ]0 S* {( cRotate the single thread 180 degree you can get a double thread, rotate the thread 120 degree twice you can get a triple thread.
) h, Q5 W* E; f2 J& I/ n
发表于 2011-8-1 10:57 | 显示全部楼层
keng21 发表于 2011-7-29 22:01
0 d( K# ?, Y; B% z5 YIt is simple, You can build a special thread in UG, just using the HELIX and SWEPT command+ M( {* Q. q$ O/ _+ j6 U
1. C ...
2 F6 y; N% [9 N/ I# l, w$ Y! x  w
Ahaha,i am so happy that someone can reply to me.so thank u a million Keng.
. O& O9 ^. z7 ~5 z9 pAccording as the method that u provided,i can handle with this problem .6 N2 p( o6 u- E3 p  W& N. w3 O1 K8 B6 N
Even though i knew a little how 2 get a complex thread with this tow Commands before.
3 x# H1 }5 x+ U7 z4 i& P' e5 h# {: O! U# Z1 _1 v
Actually I am still curious how 2 get a standerd triple thread with THREAD command in 6 q3 r" t2 m) Z- E/ g
just only one or two steps.Maybe it doesn't be done in UG.If u know,plz let me know,thx.
发表于 2011-8-1 11:12 | 显示全部楼层
This is the product with Keng's idea. Awesome
发表于 2011-8-19 21:44 | 显示全部楼层
YOU A TO NIU BI !!!
3 I: R: m/ q2 L8 c' oWO  MEN  CAN'T  UNDERSTAND!!!
GMT+8, 2025-9-19 02:32 , Processed in 0.082112 second(s), 28 queries .
