NUMBER/p(5,3)" |2 l& O3 {" E3 I n! a& w
ENTITY/sp
0 y/ {" z9 n: z' D0 UDATA/p,0,0,0,1,1,0,2,4,0,3,9,0,4,16,0
1 c) y6 S* t$ l- L- Jsp=SPLINE/(POINT/p(1,1..3)),(POINT/p(2,1..3)),(POINT/p(3,1..3)),$
/ l M3 ~1 i2 L) S F (POINT/p(4,1..3)),(POINT/p(5,1..3)) $$ 过点画多样条曲线(不封闭): t8 K, g* U" B9 I8 b6 J6 A f& w
sp=SPLINE/CLOSED,(POINT/p(1,1..3)),(POINT/p(2,1..3)),$7 G% z s8 b z# Q. E1 j$ M
(POINT/p(3,1..3)),(POINT/p(4,1..3)),(POINT/p(5,1..3))& {, s# r' Z' N* P
$$ 过点画多样条曲线(封闭)
, }/ a" U0 I2 Z2 K2 l8 W# `( A' `" I5 g
ENTITY/ln(4)8 k1 E/ T8 F- h7 `
ENTITY/sph1,sph2,block1,cone1,cone2,cyl1,solid1,solid2
( f* ~" J6 T7 a6 u7 Y2 ~& }sph1=SPHERE/CENTER,(POINT/0,0,0),RADIUS,1 $$ 画球
% ^0 M; E' ?/ ]% T; Psph2=SPHERE/(CIRCLE/CENTER,(POINT/0,0,0),RADIUS,2) $$ 画球, U2 E7 Y7 u x4 ]% r3 J
block1=SOLBLK/ORIGIN,2,2,2,SIZE,1,1,1 $$ 画方块: P* c% }4 T! I
cone1=SOLCON/ORIGIN,3,3,3,HEIGHT,1,DIAMTR,1,0 $$ 画圆锥
4 S& I# L, W9 B$ H, Icone2=SOLCON/ORIGIN,4,4,4,HEIGHT,1,DIAMTR,1,0.5,AXIS,1,0,0 $$ 画圆台 / o3 n0 I W6 F/ ?: f# s; h
cyl1=SOLCYL/ORIGIN,5,5,5,HEIGHT,1,DIAMTR,1 $$ 画圆柱
4 c" Z* J. A7 x$ D; @6 P: uln(1)=LINE/0,0,0,1,0,07 @: E8 ^$ ~: g; ? n
ln(2)=LINE/1,0,0,1,1,0
' m! I: n' ]7 t2 m) s" \ln(3)=LINE/1,1,0,0,1,0
% [: J5 o" Y4 U: P7 a9 ~& Eln(4)=LINE/0,1,0,0,0,0# s, c3 e" Y0 N) _% I+ ^
solid1=SOLEXT/ln(1..4),HEIGHT,10,AXIS,0,0,1 $$ 拉伸实体
0 _3 `8 l, A' G/ y- a$ hsolid2=SOLREV/ln(1..4),ORIGIN,0,0,0,ATANGL,360,AXIS,1,0,0 $$ 旋转实体
- `5 F$ i' k( I
$ g, \+ }, m: U, K
" R& n7 f F5 |( bENTITY/ln1,ln2
6 s- \1 w% C2 ]ENTITY/flt1,pl1,torus1
# l" a5 z! d/ V7 O% |! CNUMBER/p_coords(3)
$ v! w+ e/ I* o2 \# |9 I&FONT=&DASHED $$ 使线型变成虚线
" _1 _$ h+ j% v5 z1 Q* z: C% A0 bln1=LINE/0,0,0,1,0,0: O; E" Q- M1 k5 c$ n, @8 D* c3 G
&FONT=&SOLID $$ 使线型变成实线9 q" E6 P _2 P+ Q
ln2=LINE/0,0,0,0,1,0
/ d- ?9 T( y$ Lflt1=FILLET/ln2,ln1,CENTER,(POINT/1,1,0),RADIUS,0.2,NOTRIM $$ 画倒圆* ^8 o) n( o6 P* Y
pl1=PLANE/(POINT/0,0,0),(POINT/1,0,0),(POINT/0,1,0) $$ 画平面7 L+ }7 | m' E9 P
torus1=SOLTOR/ORIGIN,0,0,0,RADIUS,1,0.5
3 p J: t4 u5 tp_coords=CPOSF(ln1,0.25) $$ 取线的中间点
7 S; E6 k) z2 D/ v- S; t4 P1 V# z) n* h1 p* ^, a
0 L# U) | t% V2 `7 N
NOTE/0,0,'LABEL1' $$ 往ug显示区打印文字
) Y+ c' z. f5 B6 L2 n8 Y1 H( JPRINT/'LABEL2' $$ 往INFOMATION打印文字
1 e2 i: d# d1 sMESSG/'LABEL3' $$ 往信息框打印文字 |
