楼主: xcb
GRIP教程___手把手教你GRIP编程(五)
发表于 2007-6-21 17:46 | 显示全部楼层 |阅读模式
NUMBER/p(5,3)
# X& a9 O/ F1 k" Q. B; xENTITY/sp
. B9 M- p/ I! V) g! A$ S2 xDATA/p,0,0,0,1,1,0,2,4,0,3,9,0,4,16,0
6 q! u7 F, [9 a- Xsp=SPLINE/(POINT/p(1,1..3)),(POINT/p(2,1..3)),(POINT/p(3,1..3)),$; Y; ?% }2 A- r! L4 q
   (POINT/p(4,1..3)),(POINT/p(5,1..3)) $$ 过点画多样条曲线(不封闭)
# v7 G4 t5 d3 w3 c& d+ Nsp=SPLINE/CLOSED,(POINT/p(1,1..3)),(POINT/p(2,1..3)),$( ~% r2 T  R8 e0 @2 m$ y1 Y4 D
   (POINT/p(3,1..3)),(POINT/p(4,1..3)),(POINT/p(5,1..3))4 Y! {6 q8 V- u5 T( S
$$ 过点画多样条曲线(封闭)
7 }& f& g5 l8 ^' s
1 F& e8 s1 k& gENTITY/ln(4)
3 d0 D6 W0 U7 k5 T6 w0 ^7 sENTITY/sph1,sph2,block1,cone1,cone2,cyl1,solid1,solid2) h, ?7 r, w; U" f$ n# @
sph1=SPHERE/CENTER,(POINT/0,0,0),RADIUS,1 $$ 画球
) l2 F6 y) S- Osph2=SPHERE/(CIRCLE/CENTER,(POINT/0,0,0),RADIUS,2) $$ 画球! ~* z' u3 A0 d/ d
block1=SOLBLK/ORIGIN,2,2,2,SIZE,1,1,1 $$ 画方块% [  q0 K/ d9 c3 a: u- O
cone1=SOLCON/ORIGIN,3,3,3,HEIGHT,1,DIAMTR,1,0 $$ 画圆锥3 G, ]0 Z) `( u" y
cone2=SOLCON/ORIGIN,4,4,4,HEIGHT,1,DIAMTR,1,0.5,AXIS,1,0,0 $$ 画圆台 . E' o( w% p* O- G- r& J$ ~+ |5 V
cyl1=SOLCYL/ORIGIN,5,5,5,HEIGHT,1,DIAMTR,1 $$ 画圆柱! C' ^. |/ S$ c$ z; `
ln(1)=LINE/0,0,0,1,0,0
0 j# s( v1 J( L4 yln(2)=LINE/1,0,0,1,1,0
, y, O) u2 }4 E8 n0 oln(3)=LINE/1,1,0,0,1,0
, S$ z$ W* o" e. ]ln(4)=LINE/0,1,0,0,0,0
, z3 [- W  F2 E4 }8 ssolid1=SOLEXT/ln(1..4),HEIGHT,10,AXIS,0,0,1 $$ 拉伸实体5 Q6 i3 a; X; g9 u% ^- C% s2 H
solid2=SOLREV/ln(1..4),ORIGIN,0,0,0,ATANGL,360,AXIS,1,0,0 $$ 旋转实体
. o, u8 _& w7 @3 R% u' \' Y
2 h. w# T- O) ^4 v# _! u/ Z- {; B" z  z. O. U2 A* P. F0 i; @
ENTITY/ln1,ln2
6 A. w6 w8 Z. H, F$ ?# R. dENTITY/flt1,pl1,torus1
% D- A% ~4 e6 j- e/ YNUMBER/p_coords(3)
& d" R. I5 z# b&FONT=&DASHED $$ 使线型变成虚线4 [) @3 ~  i  j! u" j/ V: ~: U
ln1=LINE/0,0,0,1,0,0+ |  @" D: [6 `) G2 r
&FONT=&SOLID $$ 使线型变成实线: g, S0 W( s! _
ln2=LINE/0,0,0,0,1,01 \" Q. d. N6 n3 O) \1 v
flt1=FILLET/ln2,ln1,CENTER,(POINT/1,1,0),RADIUS,0.2,NOTRIM $$ 画倒圆
: R+ A) n' M4 T- K: I9 Vpl1=PLANE/(POINT/0,0,0),(POINT/1,0,0),(POINT/0,1,0) $$ 画平面6 V4 O( |4 u; V" F- [- q9 |  Y
torus1=SOLTOR/ORIGIN,0,0,0,RADIUS,1,0.5
1 D$ _5 V; J8 X3 x0 y. A5 x1 y. Wp_coords=CPOSF(ln1,0.25) $$ 取线的中间点
- h$ W. L5 f& d2 D4 H$ H! H) Y3 m: |" v9 o
# A# J3 N7 ~9 k: j8 n" R; D2 }NOTE/0,0,'LABEL1' $$ 往ug显示区打印文字; X% V7 g' F( R! J, }+ \/ Q
PRINT/'LABEL2' $$ 往INFOMATION打印文字- j7 K4 ?6 G/ A
MESSG/'LABEL3' $$ 往信息框打印文字
 楼主| 发表于 2007-6-21 17:46 | 显示全部楼层
看代码后面的解释,分析分析就好,比较简单
 楼主| 发表于 2007-6-21 17:49 | 显示全部楼层
不是跟书上一样很系统的讲,从6开始,再讲5个实例就打算结速,仔细学完应该能够写一些东西!
发表于 2007-6-21 20:43 | 显示全部楼层
支持版主
发表于 2007-6-24 08:50 | 显示全部楼层
支持版主
发表于 2007-6-24 19:02 | 显示全部楼层
前两天不能发言
发表于 2007-6-25 19:32 | 显示全部楼层
支持!!~~
发表于 2007-7-3 13:03 | 显示全部楼层
再支持下
发表于 2007-7-6 14:48 | 显示全部楼层
,能够讲一些具体事例吗
发表于 2007-7-17 11:29 | 显示全部楼层
支持楼主!
GMT+8, 2025-8-26 18:44 , Processed in 0.096152 second(s), 24 queries .
