NUMBER/p(5,3)/ ?) o* W O+ h- `+ o
ENTITY/sp* z) N/ [4 |4 n& v' o
DATA/p,0,0,0,1,1,0,2,4,0,3,9,0,4,16,0
8 Z0 G/ B# l$ L. l: ^ ?; y9 zsp=SPLINE/(POINT/p(1,1..3)),(POINT/p(2,1..3)),(POINT/p(3,1..3)),$
; g- E% ^* _! G (POINT/p(4,1..3)),(POINT/p(5,1..3)) $$ 过点画多样条曲线(不封闭)# p% z: h4 @5 u0 T# ^: m$ M
sp=SPLINE/CLOSED,(POINT/p(1,1..3)),(POINT/p(2,1..3)),$
% b, |* M C) s (POINT/p(3,1..3)),(POINT/p(4,1..3)),(POINT/p(5,1..3))
7 z) I# D1 C, e. a7 W$$ 过点画多样条曲线(封闭)
4 S+ B3 t/ [) Q# J( T/ U# h) ?/ R I! \: g7 @8 ^% ?+ r& D' }
ENTITY/ln(4)
- W6 {5 O* b% u: L( W# M L9 jENTITY/sph1,sph2,block1,cone1,cone2,cyl1,solid1,solid2! J! k. I& f' V$ d# I4 f
sph1=SPHERE/CENTER,(POINT/0,0,0),RADIUS,1 $$ 画球
: t9 q! N4 A) b* ]9 B' K. Wsph2=SPHERE/(CIRCLE/CENTER,(POINT/0,0,0),RADIUS,2) $$ 画球1 g( S" M$ s- e0 o! C
block1=SOLBLK/ORIGIN,2,2,2,SIZE,1,1,1 $$ 画方块
, v* `( Z) h2 Pcone1=SOLCON/ORIGIN,3,3,3,HEIGHT,1,DIAMTR,1,0 $$ 画圆锥
# L# @- X1 `& n8 | z0 fcone2=SOLCON/ORIGIN,4,4,4,HEIGHT,1,DIAMTR,1,0.5,AXIS,1,0,0 $$ 画圆台 " D; L' `. P3 `6 M8 ?( n; S
cyl1=SOLCYL/ORIGIN,5,5,5,HEIGHT,1,DIAMTR,1 $$ 画圆柱5 B' ]: A0 k8 K( \$ K
ln(1)=LINE/0,0,0,1,0,0* |* f! X/ f5 q6 [
ln(2)=LINE/1,0,0,1,1,0
. O r, A: J, e2 jln(3)=LINE/1,1,0,0,1,0
4 k/ W1 I* w6 X! |+ qln(4)=LINE/0,1,0,0,0,0; V' @9 [" G! G2 F& N2 S' ]
solid1=SOLEXT/ln(1..4),HEIGHT,10,AXIS,0,0,1 $$ 拉伸实体, y+ M4 i( N, N9 e
solid2=SOLREV/ln(1..4),ORIGIN,0,0,0,ATANGL,360,AXIS,1,0,0 $$ 旋转实体
: p1 d$ `# X% r7 I8 Q7 o2 ^! N; ^% B; c
( `. J% A( q5 i# S
ENTITY/ln1,ln22 R% x4 M2 j1 D2 T/ w: j+ J3 g6 }
ENTITY/flt1,pl1,torus1! T! h$ O7 [3 J7 T
NUMBER/p_coords(3)6 _% _' o. N$ T' i2 y& X/ w% c1 l
&FONT=&DASHED $$ 使线型变成虚线
" X/ K( I/ @* [+ [$ o ~, ^" ~- f0 @% @ln1=LINE/0,0,0,1,0,03 Y E7 E2 E9 i, P- e) j/ i
&FONT=&SOLID $$ 使线型变成实线
\5 c# D# x: l/ v H! k$ {ln2=LINE/0,0,0,0,1,0
1 w3 l2 l9 `% F9 _) ]+ B& |- vflt1=FILLET/ln2,ln1,CENTER,(POINT/1,1,0),RADIUS,0.2,NOTRIM $$ 画倒圆
" @3 a! u8 B) }+ Ipl1=PLANE/(POINT/0,0,0),(POINT/1,0,0),(POINT/0,1,0) $$ 画平面
& _8 [& m8 j* d6 ?4 ? p% k; ctorus1=SOLTOR/ORIGIN,0,0,0,RADIUS,1,0.5
6 u. x! l9 h( G: F8 X/ B+ O2 o hp_coords=CPOSF(ln1,0.25) $$ 取线的中间点- |& i: d- D Z) V: }5 P( h
' k: h/ Q2 v6 I# A# C! \
6 b( Q9 } {8 \, f, mNOTE/0,0,'LABEL1' $$ 往ug显示区打印文字
9 U& g8 b. t& }; Y+ [PRINT/'LABEL2' $$ 往INFOMATION打印文字0 y* c6 D6 [7 W9 ]
MESSG/'LABEL3' $$ 往信息框打印文字 |
