楼主: xcb
GRIP教程___手把手教你GRIP编程(五)
发表于 2007-6-21 17:46 | 显示全部楼层 |阅读模式
NUMBER/p(5,3)
$ \2 s7 _. z, K/ B/ A' `: x' LENTITY/sp
6 c: S8 F! q4 W- A- G. _DATA/p,0,0,0,1,1,0,2,4,0,3,9,0,4,16,0
! ]( [; v& P* U7 N. msp=SPLINE/(POINT/p(1,1..3)),(POINT/p(2,1..3)),(POINT/p(3,1..3)),$
3 f) a+ i3 Y9 ]; i0 B- i   (POINT/p(4,1..3)),(POINT/p(5,1..3)) $$ 过点画多样条曲线(不封闭)8 m. L9 }( t7 N: ^# @: v
sp=SPLINE/CLOSED,(POINT/p(1,1..3)),(POINT/p(2,1..3)),$/ T+ G4 _0 m, V2 r
   (POINT/p(3,1..3)),(POINT/p(4,1..3)),(POINT/p(5,1..3))4 I. E% ~7 a' P" d2 e
$$ 过点画多样条曲线(封闭)6 }# w1 x: t, o: H& o) }
( J3 d" J) s0 J# c1 c- ^* wENTITY/ln(4). Z% l( ?4 ~* r* q% u
ENTITY/sph1,sph2,block1,cone1,cone2,cyl1,solid1,solid2
7 V. A8 l; [' wsph1=SPHERE/CENTER,(POINT/0,0,0),RADIUS,1 $$ 画球
% z4 D1 j/ F3 |sph2=SPHERE/(CIRCLE/CENTER,(POINT/0,0,0),RADIUS,2) $$ 画球
6 t- t/ G( ]' b% `8 R; mblock1=SOLBLK/ORIGIN,2,2,2,SIZE,1,1,1 $$ 画方块
8 Z! a, _" a8 `) b7 rcone1=SOLCON/ORIGIN,3,3,3,HEIGHT,1,DIAMTR,1,0 $$ 画圆锥
3 U5 p: g, C, ]: {! g1 H' ~% L1 Pcone2=SOLCON/ORIGIN,4,4,4,HEIGHT,1,DIAMTR,1,0.5,AXIS,1,0,0 $$ 画圆台 , M& i% [$ [) F7 Y. j  v
cyl1=SOLCYL/ORIGIN,5,5,5,HEIGHT,1,DIAMTR,1 $$ 画圆柱$ c" {4 b7 f1 d- o+ v
ln(1)=LINE/0,0,0,1,0,0
6 L% X: [. N: s# e. F5 L6 Qln(2)=LINE/1,0,0,1,1,05 b$ Z# d. x0 }+ t  y& t
ln(3)=LINE/1,1,0,0,1,0% C* ]  ~8 Q$ l# a3 H
ln(4)=LINE/0,1,0,0,0,0- @4 ^, I! p' ~) D1 Y% q
solid1=SOLEXT/ln(1..4),HEIGHT,10,AXIS,0,0,1 $$ 拉伸实体
7 }* c$ k& z1 d  b' zsolid2=SOLREV/ln(1..4),ORIGIN,0,0,0,ATANGL,360,AXIS,1,0,0 $$ 旋转实体- }  A$ ?8 s7 s$ k& i1 e
* v6 N3 B/ j, v
3 r+ _" g4 t$ NENTITY/ln1,ln2
* l+ d% E4 g5 `8 |ENTITY/flt1,pl1,torus1. W, }# s0 ~. r5 Y0 @- W
NUMBER/p_coords(3)( T( n: z7 u  \' {+ i% t  j0 F
&FONT=&DASHED $$ 使线型变成虚线9 n4 x6 P3 ^) X4 ]  f
ln1=LINE/0,0,0,1,0,0
  f0 F9 ^4 L# n7 ]&FONT=&SOLID $$ 使线型变成实线
2 }7 j* i! F: ]) m7 i* Cln2=LINE/0,0,0,0,1,0
. U. L( U# ^( }$ f: A& N. aflt1=FILLET/ln2,ln1,CENTER,(POINT/1,1,0),RADIUS,0.2,NOTRIM $$ 画倒圆  Z$ L: c3 k/ s2 Q5 p
pl1=PLANE/(POINT/0,0,0),(POINT/1,0,0),(POINT/0,1,0) $$ 画平面9 H9 m- d8 t7 @4 O" X& g7 X( B
torus1=SOLTOR/ORIGIN,0,0,0,RADIUS,1,0.5
, S& [: h- Y  _/ ^% Zp_coords=CPOSF(ln1,0.25) $$ 取线的中间点
* l2 [) Q3 b* ?2 Q! s% e. |- n: e- T/ ]7 C$ h2 P( {6 A
4 X* Q# M; g' \+ R, I5 ~( D
NOTE/0,0,'LABEL1' $$ 往ug显示区打印文字
0 W% n7 l* F4 Y9 K- X8 oPRINT/'LABEL2' $$ 往INFOMATION打印文字: R% b; N5 o* D5 {' U7 `
MESSG/'LABEL3' $$ 往信息框打印文字
 楼主| 发表于 2007-6-21 17:46 | 显示全部楼层
看代码后面的解释,分析分析就好,比较简单
 楼主| 发表于 2007-6-21 17:49 | 显示全部楼层
不是跟书上一样很系统的讲,从6开始,再讲5个实例就打算结速,仔细学完应该能够写一些东西!
发表于 2007-6-21 20:43 | 显示全部楼层
支持版主
发表于 2007-6-24 08:50 | 显示全部楼层
支持版主
发表于 2007-6-24 19:02 | 显示全部楼层
前两天不能发言
发表于 2007-6-25 19:32 | 显示全部楼层
支持!!~~
发表于 2007-7-3 13:03 | 显示全部楼层
再支持下
发表于 2007-7-6 14:48 | 显示全部楼层
,能够讲一些具体事例吗
发表于 2007-7-17 11:29 | 显示全部楼层
支持楼主!
GMT+8, 2025-6-27 13:45 , Processed in 0.047727 second(s), 21 queries .
