楼主: xcb
GRIP教程___手把手教你GRIP编程(五)
发表于 2007-6-21 17:46 | 显示全部楼层 |阅读模式
NUMBER/p(5,3)
5 ?. k& Q8 z2 g# X# CENTITY/sp0 G3 q; K" U! C3 a3 b( g
DATA/p,0,0,0,1,1,0,2,4,0,3,9,0,4,16,0( ?2 R7 }9 K6 T; r
sp=SPLINE/(POINT/p(1,1..3)),(POINT/p(2,1..3)),(POINT/p(3,1..3)),$  O/ e$ _+ n. \6 w* s) k1 B( L
   (POINT/p(4,1..3)),(POINT/p(5,1..3)) $$ 过点画多样条曲线(不封闭)( H/ @& C% a9 G
sp=SPLINE/CLOSED,(POINT/p(1,1..3)),(POINT/p(2,1..3)),$
) e; H3 {5 A2 J& J   (POINT/p(3,1..3)),(POINT/p(4,1..3)),(POINT/p(5,1..3))
" Y0 }  E, _7 e! @/ H$$ 过点画多样条曲线(封闭)
6 d1 H/ M& ~+ k% i- W1 v! B; G- n0 R6 y* C/ N/ u  f
ENTITY/ln(4)0 u4 D% w+ V; G7 I, `7 N- T$ b1 F8 k1 W
ENTITY/sph1,sph2,block1,cone1,cone2,cyl1,solid1,solid29 w1 N8 T! A$ Q  j! y0 a
sph1=SPHERE/CENTER,(POINT/0,0,0),RADIUS,1 $$ 画球4 r$ s* ]% z* Z* R
sph2=SPHERE/(CIRCLE/CENTER,(POINT/0,0,0),RADIUS,2) $$ 画球2 \# S4 O8 r6 j1 l7 A! C0 z4 ]! G& g
block1=SOLBLK/ORIGIN,2,2,2,SIZE,1,1,1 $$ 画方块
) ?$ s7 h" k( \cone1=SOLCON/ORIGIN,3,3,3,HEIGHT,1,DIAMTR,1,0 $$ 画圆锥
8 p/ G! A* W3 u, Wcone2=SOLCON/ORIGIN,4,4,4,HEIGHT,1,DIAMTR,1,0.5,AXIS,1,0,0 $$ 画圆台 # J  \- P# J2 o! f+ j
cyl1=SOLCYL/ORIGIN,5,5,5,HEIGHT,1,DIAMTR,1 $$ 画圆柱6 W2 J% W; o$ o  Q/ H  O1 W
ln(1)=LINE/0,0,0,1,0,0
! a( S. t" t1 N" @ln(2)=LINE/1,0,0,1,1,0: l' `; {2 w0 }5 V2 z5 _
ln(3)=LINE/1,1,0,0,1,01 o9 |" @. g5 G) N  @  `
ln(4)=LINE/0,1,0,0,0,0% C6 G& o+ S) u, b5 v
solid1=SOLEXT/ln(1..4),HEIGHT,10,AXIS,0,0,1 $$ 拉伸实体! ]1 g7 F) {( C& N3 n) L% ?
solid2=SOLREV/ln(1..4),ORIGIN,0,0,0,ATANGL,360,AXIS,1,0,0 $$ 旋转实体
8 r2 }$ d, s% ?! c' i; g* L* S; \$ R  j) M$ [: H2 f- D
# Q$ E" {+ [7 K8 b4 c. Y7 W
ENTITY/ln1,ln2
) x. O# m0 r) t' t4 fENTITY/flt1,pl1,torus15 Y0 r+ x; y7 g
NUMBER/p_coords(3)- q9 P" U) ~7 }1 s7 _
&FONT=&DASHED $$ 使线型变成虚线9 n! E* o* q% d9 k8 B9 A# G3 i6 E
ln1=LINE/0,0,0,1,0,0! O% j& ?& U6 ]& m- J; E' N
&FONT=&SOLID $$ 使线型变成实线
" O" H$ H; V$ n. H( rln2=LINE/0,0,0,0,1,0
2 [1 K$ M+ U0 B3 V. x8 lflt1=FILLET/ln2,ln1,CENTER,(POINT/1,1,0),RADIUS,0.2,NOTRIM $$ 画倒圆
" c1 Z/ v) G/ G& }pl1=PLANE/(POINT/0,0,0),(POINT/1,0,0),(POINT/0,1,0) $$ 画平面
4 E% A6 h2 j4 N9 B  Rtorus1=SOLTOR/ORIGIN,0,0,0,RADIUS,1,0.55 _% i3 B7 Z0 h
p_coords=CPOSF(ln1,0.25) $$ 取线的中间点+ }: K. B, a( {' S
: b) ]4 l& ?. D/ G8 x7 V: I* h: J! j, A' q2 {* [0 r
NOTE/0,0,'LABEL1' $$ 往ug显示区打印文字
* f  Z" W2 B( p) [7 l+ PPRINT/'LABEL2' $$ 往INFOMATION打印文字0 E, c" @" U& o8 e
MESSG/'LABEL3' $$ 往信息框打印文字
 楼主| 发表于 2007-6-21 17:46 | 显示全部楼层
看代码后面的解释,分析分析就好,比较简单
 楼主| 发表于 2007-6-21 17:49 | 显示全部楼层
不是跟书上一样很系统的讲,从6开始,再讲5个实例就打算结速,仔细学完应该能够写一些东西!
发表于 2007-6-21 20:43 | 显示全部楼层
支持版主
发表于 2007-6-24 08:50 | 显示全部楼层
支持版主
发表于 2007-6-24 19:02 | 显示全部楼层
前两天不能发言
发表于 2007-6-25 19:32 | 显示全部楼层
支持!!~~
发表于 2007-7-3 13:03 | 显示全部楼层
再支持下
发表于 2007-7-6 14:48 | 显示全部楼层
,能够讲一些具体事例吗
发表于 2007-7-17 11:29 | 显示全部楼层
支持楼主!
GMT+8, 2025-6-27 13:52 , Processed in 0.051358 second(s), 22 queries .
