查看: 1583|回复: 2
[教程] 标注3维曲线
发表于 2008-4-29 13:22 | 显示全部楼层 |阅读模式
标注3维曲线
1. In Modeling: After Creating a 3 D curve, Moving WCS origin to curve’ End_point1. Drawing a line which length is equal End_point2’s Xc value. Then Using Insert Curves Point SET, Creating N Points ( Equal Arc Length).   m) |0 D7 H8 X0 c# U8 N/ E
2. In Drafting: Drawing Add View (Adding Front and Top and TFR_TRI View); Expand View; (Using Insert Basic curve line, through Point drawing N Vertical Lines as following Fig.); Insert Dimension( Horizontal and vertical as following Fig.) - c9 N1 G! L8 r5 b0 ^; Z! r
: [4 x" L( h4 w/ _$ a) h" \) j& B
So you can clearly represent X,Y,Z of each point.. l) z+ t; j, E; ]
发表于 2008-4-30 00:17 | 显示全部楼层
没什么太大的实际用处
发表于 2008-5-1 17:53 | 显示全部楼层
Go guy!Thank you for your help,I immediately understand When I have read your information .
- A* Z' v* B. @. TBut I don't think it isn't useful for us in practicein.
GMT+8, 2025-3-4 19:14 , Processed in 0.111476 second(s), 24 queries .
