楼主 |
发表于 2013-1-8 17:04
显示全部楼层
Contour Profile Ring Height Control8 h- w8 |. Q. D/ U0 u% Q
Shift the tool along its axis to determine contact ring
7 N1 X5 }! j; RConstant or Variable Ring height# J# s0 x$ Y* L4 Q$ x
Conical tools are supported.
2 V. K8 Q# a" \/ ?% }& lWill not gouge the floor Customer value
0 s6 D8 U1 ]5 T- [, iWith convex curved walls, shifting the tool dramatically reduces the scallops, providing better finish with shorter machining time.# ?( [( L% m. }/ o+ T
Variable shift equalizes the tool wear along the flutes- P- `" d' F% q2 ~( \" D
