查看: 1645|回复: 1
一些冲压模具专业英语
发表于 2012-8-16 17:13 | 显示全部楼层 |阅读模式
压力铸造模具   die-casting die
, N9 Y6 b1 G8 L/ ]7 B0 G" W压铸模零部件          , q: g  z1 M& @
定模   fixed die, cover die        ! N" F% ^6 N; j2 C  g& F9 a" X) g
定模座板   fixed clamping plate        . Y5 @& n4 l# y1 h
定模套板   bolstor, fixed die        : u, O& ]3 K; b" T5 i7 Q
动模   moving die,ejector die        . V0 z3 P! D/ U2 u+ s9 D
动模座板   moving clamping plate        : P, b1 p: l5 |2 v, D2 U
直流道   sprue        9 ^% O$ ^: i! b! a, r& E& U
横流道   runner5 v9 q9 j% N; D3 s# a/ G( q( F
冲压英语5 ?# j/ R" ?4 s+ L5 a
冲压常词汇9 w# r. q& Y; O" i, ~& Z
stamping, press冲压
  [7 q" ~( ?! |! {punch press, dieing out press冲床
- o" v$ \* Q# g6 F7 Wuncoiler & strainghtener整平机  \: G7 J0 m. l+ }0 g6 w& V
feeder送料机$ E9 A! ?1 D) P0 }
rack, shelf, stack料架
* u8 T& n2 y9 {$ Icylinder油缸
, K' G; x" B: E/ I. _robot机械
' v* Q; s" _7 V# ^' Otaker取料机
4 E9 M* h/ ?* `. Oconveyer belt输送带0 r4 O& U; i/ R4 g1 Z! n
transmission rack输送架- ^" R! B5 B; _2 r2 u( I" m( d, F' ]: {
top stop上死点% y$ Z) d8 U$ O, ?. E+ b
bottom stop下死点
5 j; Z% l4 q1 w! ^+ `one stroke一行程/ O5 J8 c) [4 R) H4 p4 l$ Y7 F. U
inch寸动1 m) h& M! W% @1 ^" z: R
to continue, cont.连动
! h! F: c# z- F( Pto grip(material)吸料( A0 M9 d  G. \) q
location lump, locating piece, block stop 定位块5 p: r! n& O+ X+ W
reset复位" ^& D' _2 S( D9 Y# D
smoothly顺利: z" e# x# e& T8 ?5 H  F, c+ q5 x4 g
dent压痕
9 H$ }2 @* v: l4 s1 q4 I, Z: Lscratch刮伤6 Q  U" o. V% D# A& w' |6 A' H0 B
deformation变形9 {* H, H/ h, f: l* k/ v
filings铁削1 Y& L  R7 Q4 f8 s, {( S  d5 e
to draw holes抽孔
- L1 ?- ~; L, Zinquiry, search for查寻- T# _) l- [# Q  _6 ]: H) G7 O' j, U
to stock, storage, in stock库存% f  ]- {* G* |
receive领取
& j" U2 O! f; E+ ?% K9 Wapproval examine and verify审核
5 I  C: _9 J9 I7 Vprocessing, to process加工
/ t7 k0 _1 I. @7 j/ L2 E2 l3 M3 Cdelivery, to deliver 交货0 E( ~) o7 Y% H+ C. \" ]
to return delivenry to.4 w* m" f! [4 k/ o( L
to send delinery back0 V, U8 ?- h5 U5 ~
to retrn of goods退货. q; y. t- i( {1 }- s! H3 V* U
registration登记
/ B( x5 w/ L0 Uregistration card登记卡
; f  `2 H, J2 [1 d- eto control管制7 U: P: f9 q& W9 W+ |4 X0 B
to put forward and hand in提报$ I0 e- u. @: j
safe stock安全库存( i) ?2 |. [: U# h/ X. e' ~
acceptance = receive验收/ b! e& w5 U# s2 @: ~* x8 f' H) U4 R( u
to notice通知) l  \/ H7 ?: w2 ]/ U# I7 s  P
application form for purchase请购单7 g, S9 A/ k' X4 s: J8 l
consume, consumption消耗  ]. u  \9 w0 m
to fill in填写
; o9 K7 ~. O8 |3 [3 y8 E+ o8 P) P% I. {1 U% xabrasion磨损- O, p; f, o$ |7 g) |, P7 Z0 w) E) S
reverse angle = chamfer倒角
+ k  u3 s4 M4 U& V( G1 ]7 N) acharacter die字模
* Z4 K( q5 K2 ]8 L; ?* V6 F! x4 Dto collect, to gather收集
6 ^& H0 V' S- r0 y0 d+ Nfailure, trouble故障$ g  _& g8 l# j
statistics统计
! Q9 [1 s& ~! V6 A4 h( r- G  W( |demand and supply需求
4 E, v8 n  {1 {+ ]: @career card履历卡
" ?; j8 i8 P/ o$ rto take apart a die卸下模具
, p: Y9 i9 R  \0 Sto load a die装上模具1 g! `% g8 W+ j! N: h
to tight a bolt拧紧螺栓; U7 R2 T; S5 @( L, g. j3 l. o, ^+ V
to looser a bolt拧松螺栓
* G9 t' y+ g6 _8 u1 m8 pto move away a die plate移走模板! N+ {' `' K1 [( p* g$ e' V
easily damaged parts易损件
) U. A# X4 O: D7 l" sstandard parts标准件# X& Y, K# w+ [/ X
breaking.(be)broken,(be)cracked 断裂* Y: u  D6 u$ p  z# B9 D2 K" e9 \
to lubricate润滑
+ L: u) y- x, k) _1 bcommon vocabulary for die engineering
3 ^# z: w. r2 C9 j" c2 b1 m
5 t( W; f2 c  Z) P! U1 M8 y
  `  }6 [  N' o( Q( x. y$ o. U7 I: `* [  |+ m: s5 T* H
* q4 u+ G" O" {5 [模具工程常用词汇
( r0 d+ @$ V& r+ {' }$ cdie 模具
% f5 |; d: x( q) U: {( bfigure file, chart file图档
* S) e$ j" G0 L' }9 W, X. ccutting die, blanking die冲裁模! e4 `2 w2 s" |
progressive die, follow (-on)die 连续模
- I; q6 j/ H7 ^' wcompound die复合模
' p7 ^) t) A0 O2 Q, W' Xpunched hole冲孔! S0 a! W' Y( J" c
panel board镶块
. {9 H# T7 ?2 j/ Uto cutedges=side cut=side scrap切边
/ ^8 m/ N1 k1 d) q$ M  gto bending折弯5 n6 ?3 k: m* B( o6 b: f
to pull, to stretch拉伸0 s0 A2 A" F5 S9 m2 J( @
Line streching, line pulling线拉伸# h2 P/ |" f  G6 l  n
engraving, to engrave刻印' T/ C6 `; `( X$ F. u
upsiding down edges翻边
. i% w( M, T% m% Q$ q$ f/ v! _5 Zto stake铆合
5 Y8 r, `2 [' |) I* ddesigning, to design设计8 p6 z1 U% l8 v  A# ?/ J& B& s* K
design modification设计变化& l. D5 g8 O9 q' h
die block模块
3 L4 u6 a& D* \" T; `7 T6 R. Lfolded block折弯块& b# q5 h# c3 J* h2 {6 I& ?
sliding block滑块1 g' X5 t7 d0 N) x
location pin定位销
7 Q1 ^4 B" J, h0 ~+ u; Olifting pin顶料销
3 G* e2 A- ^6 x" F7 y- D% t  j' l& }die plate, front board模板
/ q4 [: e* H3 W- T7 U. u6 Mpadding block垫块
! [( O, O5 u5 Astepping bar垫条1 x* K' Y% g* J! ^2 l! C9 H2 l2 R
upper die base上模座
0 J! J* E2 l9 ]3 d, n8 {: E6 flower die base下模座+ r9 n( \  {) U, v# F; V
upper supporting blank上承板' }! s) s  W1 b' O- |
upper padding plate blank上垫板
/ z* `, i0 Q4 T! `spare dies模具备品
. S  _1 }7 A' U- ~8 _4 Q- Nspring 弹簧8 m2 [5 ]% s6 ~; T: j* `
bolt螺栓
0 L3 f# M" Q& X6 I
发表于 2012-9-29 21:27 | 显示全部楼层
fffffg古古怪怪哥哥哥哥
GMT+8, 2025-8-12 14:31 , Processed in 0.153084 second(s), 23 queries .
