查看: 1976|回复: 0
一些五金冲压模具专业英语
发表于 2012-8-16 17:15 | 显示全部楼层 |阅读模式
模具工程常用词汇9 w2 a' D8 f7 D8 A& P8 q
( f" s* V6 d. X2 r    模具钢材5 a: N" d, J2 C) ?, N
    alloy tool steel 合金工具钢 aluminium alloy 铝合金钢 bearing alloy 轴承合金 blister steel 浸碳钢 bonderized steel sheet 邦德防蚀钢板. F/ W; z0 O6 |; M6 L  Q% S) S
    carbon tool steel 碳素工具钢
2 ^3 O. V. M$ r: B; {( `& [    clad sheet 被覆板/ `* m: X& n3 E: t
    clod work die steel 冷锻模用钢4 i/ w# C3 J( Z6 z: [/ p
    emery 金钢砂 ferrostatic pressure 钢铁水静压力forging die steel 锻造模用钢+ g& Y& {( N$ j! G
    galvanized steel sheet 镀锌铁板
- @0 s3 |0 O: v    hard alloy steel 超硬合金钢
1 w' V& k0 z: o# z. O, `* ^' f# {" B    high speed tool steel 高速度工具钢
" B+ @' }/ i* H8 y7 Y+ v, f    hot work die steel 热锻模用钢6 B9 k, d$ x" `/ G$ z% @& Y
    low alloy tool steel 特殊工具钢
7 s" S  g8 d. H: c3 W    low manganese casting steel 低锰铸钢
2 b! q  a4 F0 M! o% p: d( R    marging steel 马式体高强度热处理0 Q& }2 I* q% {3 X# h! |6 X
    martrix alloy 马特里斯合金
# Q3 B6 o/ J, m- {8 `/ G    meehanite cast iron 米汉纳铸钢: m  W% V+ \0 W1 s* s+ t
    meehanite metal 米汉纳铁& F8 F5 g" z) s3 D! g0 W0 g
    merchant iron 市售钢材
* \4 J8 s. F4 ~9 O: [    molybdenum high speed steel/ d/ i7 t( x& ^& w  `# f) e) S
    钼系高速钢 molybdenum steel
. i0 \  _. a3 w2 X& Y    钼钢 nickel chromium steel 镍铬钢
, e2 U9 m  S+ S    prehardened steel 顶硬钢& ^3 i3 y! R! ?* l% y1 [' |) X9 y
    silicon steel sheet 硅钢板
5 Z9 J( L. l" ]. E9 u    stainless steel 不锈钢
; ~/ O0 w5 w: F- R+ e; U    tin plated steel sheet 镀锡铁板3 ^' n  |; ^. N1 h. I: L
    tough pitch copper 韧铜) E% u: U5 x9 f- r7 r1 ?
    troostite 吐粒散铁7 f, W) G  z/ [
    tungsten steel 钨钢
  o  v# q+ c. t    vinyl tapped steel sheet 塑料覆面钢板3 U9 F* M, p; b: a0 m  m. \
    四、模具零件: mold components
2 i- w1 Y: }5 ^, \, A1 }1 p    三板模:3-plate mold
' Q- l) u2 |+ ^) g    二板模:2-plate mold
1 y: I) ~- y4 k# w: t  ]5 J) ~    边钉/导边:leader pin/guide pin
( B8 k3 l$ N* D. Y" |    边司/导套:bushing/guide bushing/ V0 E7 f( F0 E1 A3 R3 `
    中托司:shoulder guide bushing
: g. Q' f8 |5 S1 x    中托边L:guide pin
5 [9 h2 N5 s. P/ ?    顶针板:ejector retainner plate9 T" R3 H( Q! R6 z8 v
    托板: support plate
6 ]! W" W: K5 t9 [: B4 G$ K    螺丝: screw
/ T- n( n( v! K. R1 n8 U    管钉:dowel pin
' ?2 R4 C! `5 H1 ?  Z7 E% c, r    开模槽:ply bar scot
9 k1 l, X4 t% D, E! J# r    内模管位:core/cavity inter-lock
( V: U- v" O$ {- r% r# k, N    顶针: ejector pin! g2 h9 [6 e7 b
    司筒:ejector sleeve
& K- j+ z* d- \( E0 |    司筒针:ejector pin% b5 J* L) F7 ^6 x
    推板:stripper plate
$ {! |( f% n* Q    缩呵:movable core,return core core puller* [8 h' b( ?8 G$ l
    扣机(尼龙拉勾):nylon latch lock: O3 Z4 f, q2 Y. T  w. ]+ n
    斜顶:lifter
2 _+ Q* V. |( N    模胚(架): mold base0 ]/ Y9 B6 d, k
    上内模:cavity insert
3 ~4 v' q/ R; K( |  J+ o/ o; k    下内模:core insert6 {# N/ r& r2 l% s' ^8 A: P
    行位(滑块): slide$ u0 T- i+ B' Q3 `" o% Z1 D& Z
    镶件:insert
2 \9 n. R+ H# e0 A    压座/斜鸡:wedge7 o% F* Y; `) h3 \# t1 B) R: W
    耐磨板/油板:wedge wear plate( ~4 q0 ^+ u4 R+ ]
    压条:plate/ p% E8 O/ U; f
    撑头: support pillar
) }9 B6 M+ K$ Q$ k' b$ `    唧嘴: sprue bushing
) _; v; y6 @+ N2 x    挡板:stop plate! G7 s8 Z% z$ x2 s9 A1 }
    定位圈:locating ring
6 H* v2 b. Y, e  B$ Y8 `* Q    锁扣:latch: |) D! J0 P: Z8 c4 k+ I
    扣鸡:parting lock set
/ m( B* }% u. q  ~; ^  o    推杆:push bar3 M) b% m/ m: _8 k6 C/ a
    栓打螺丝:S.H.S.B
* M" n$ i2 U7 [0 }1 i, @; M    顶板:eracuretun
, y9 R9 l* s3 R    活动臂:lever arm$ ~9 y2 I' {+ o: q) A
    分流锥:spure sperader
4 t; X8 B& l4 N. U2 W    水口司:bush
5 v3 q2 _" R! m" L4 G/ |- w    垃圾钉:stop pin
. _; y2 X/ b+ F+ X7 n8 c, y* Z    隔片:buffle; d0 O; d. h- Q4 j9 Q& M
    弹弓柱:spring rod
' ?! k' Z6 x* t    弹弓:die spring
2 y  i, j: D* `    中托司:ejector guide bush2 G: |8 k# J& u4 N$ [9 x/ l' {7 O
    中托边:ejector guide pin* t' c7 ~/ z( o2 [5 `+ ?- f
    镶针:pin
$ j- t1 o! s+ `# F7 F4 t  d    销子:dowel pin
% i5 W, s& _" C. D6 z2 s    波子弹弓:ball catch4 q" q* H  @. W3 D& H
    喉塞: pipe plUG
1 c& u$ P: N) q! p' m% N8 p    锁模块:lock plate
" D; ?, a& G0 u7 B# V, h    斜顶:angle from pin, E! H9 B' b& z9 b. z
    斜顶杆:angle ejector rod
7 e; i2 u) r; K' i! v6 H, P$ C    尼龙拉勾:parting locks/ O8 h- O( H3 L. r. n  R
    活动臂:lever arm
6 b! }5 N) i. J0 u2 ?    复位键、提前回杆:early return bar
) H& {, }" P+ A" F7 m3 y+ J    气阀:valves8 A) }) S) @) X$ {# B+ O
    斜导边:angle pin' B& H! g6 K7 g  h+ [
术语:terms! J: I6 |$ p& h8 \0 V# i
    承压平面平衡:parting surface support balance
. i% _& L4 l) v$ E7 e" u- H8 L    模排气:parting line venting$ D$ B9 i) f2 l2 j8 o
    回针碰料位:return pin and cavity interference# D: J6 D- ?3 E* H
    模总高超出啤机规格:mold base shut hight
5 s( K' s4 @& o. g; O    顶针碰运水:water line interferes withejector pin+ |; a3 N, v) `; `6 Z& V
    料位出上/下模:part from cavith (core) side0 r3 ]; N1 F4 u" F' p) B2 E. M* Z
    模胚原身出料位:cavity direct cut on A-plate,core direct cut on B-plate.
' m* Q3 f1 Y" w7 `* m2 J% b    不准用镶件: Do not use (core/cavity) insert. T8 J$ S; p! J% `- _
    用铍铜做镶件: use beryllium copper insert1 u; v  G3 @& c# Y! A+ o, m
    初步(正式)模图设计:preliinary (final) mold design
GMT+8, 2025-8-12 14:23 , Processed in 0.120110 second(s), 24 queries .
